Great...I'll give that a try. What would you think about using a bit of Axle grease on the end of the grip? There's no opening so it wouldn't drip out.
Looks like you have some type of cable clamps on your fork tubes. I'd so, where did you get them?Yes—haha mine is routed thru the hole and has 2 clips on the downtubeView attachment 137675ube—-
I think you're right. I should probably wash it more often whether it needs it or not. The storage room I rented is actually inside of a building and also climate controlled. That should help.If you’re near the coast the salt is in the air. No storm needed. The humidity and salt air will corrode and rust any unprotected surfaces in a short time. Unfortunately the storage unit probably won’t offer much protection. Best of luck
I wouldn’t use grease. The tape should do the trick. The climate controlled storage unit will definitely help a lot.Great...I'll give that a try. What would you think about using a bit of Axle grease on the end of the grip? There's no opening so it wouldn't drip out.
It’s an ongoing problem with parts and accessories overall. No one makes the stuff for our bikes anymore. There used to be plenty but it’s a small market compared to Harley and everyone is making Harley stuff.Ok...I'll try it. I still can't understand why BIG DOG decided to go with a larger size handlebar, and then not offer different styles to choose from. It really doesn't make good business sense. All it accomplishes is to prevent us from using all the aftermarket products offered to Harley and others.
I hate to have to mention this but being about 5 miles from the ocean on a short canal just off the St Lucie river for 12 years the only way you are going to get away from the salt is to head back to Kentucky. The dog will need constant care, think weekly or sooner if you ride in the evenings.I think you're right. I should probably wash it more often whether it needs it or not. The storage room I rented is actually inside of a building and also climate controlled. That should help.
See post 266— eBay or HDM has them….Arlen Ness on eBay has chrome!Looks like you have some type of cable clamps on your fork tubes. I'd so, where did you get them?
You can be sure I'm going to wash often. Like I said, I can't do this again !I hate to have to mention this but being about 5 miles from the ocean on a short canal just off the St Lucie river for 12 years the only way you are going to get away from the salt is to head back to Kentucky. The dog will need constant care, think weekly or sooner if you ride in the evenings.
That is just my experience in Florida, wet salt air all the time if your close to the coast.
Remember a little company named Hewlet Packard? HP for short. They tried the propriotory computer crap just before they tanked. Need parts? Gotta buy from them. I guess Sheldon was a fan?Ok...I'll try it. I still can't understand why BIG DOG decided to go with a larger size handlebar, and then not offer different styles to choose from. It really doesn't make good business sense. All it accomplishes is to prevent us from using all the aftermarket products offered to Harley and others.
It's called Proprietary and means I designed it, have rights to it, and you want it you will have to buy it from me. Works for some not for others.Ok...I'll try it. I still can't understand why BIG DOG decided to go with a larger size handlebar, and then not offer different styles to choose from. It really doesn't make good business sense. All it accomplishes is to prevent us from using all the aftermarket products offered to Harley and others.
I’d be concerned it would displace. I used teflon tap because it provided the thickness to absorb the play and not rattle but not be so hard it would bind. Can also vary the number of wraps to perfect it.Great...I'll give that a try. What would you think about using a bit of Axle grease on the end of the grip? There's no opening so it wouldn't drip out.
AbsolutelyQuestion: Since there's only a small amount of oil that remains in the crankcase, can I change out the cam Cover without draining the oil? I hate to drain it if I don't have to because I just put it in when I installed the oil tank.
