Mickeetwo
Try changing the orientation of your spike air filter. If its forward, point it up, and vice versa....and check if the auxiliary bowl vent screw has been removed? S&S recommends removing it when changing breathers.
X2
The air filter has been on for quite awhile. I'll try changing the direction of it. Let you know..........Try changing the orientation of your spike air filter. If its forward, point it up, and vice versa....and check if the auxiliary bowl vent screw has been removed? S&S recommends removing it when changing breathers.
Never a stumble for me anymore after I rejetted, unless it's raining hard. Spike always facing upWeather will play a part in it also. When I had my spike air filter pointed forward on cool days the stumble was worse. Hot and dry days it was not as bad. Always around 65mph. Since I pointed it up I've had no problem with it. You can jet it till your blue in the face, but if you ride in all types of weather like I do the stumble will remain. This is one of the reasons a lot of people don't like the spike air filter. This is what I've experienced with the spike air filter, hope it helps
I guess I should have added that I've never had the stumble with it pointed up, when I had it pointed forward I tried to rejet and adjust the carb several times, and could never get the stumble to go away. I should have been more clear. I've riden in the rain several times and with a rain sock on I didn't have a problem.Never a stumble for me anymore after I rejetted, unless it's raining hard. Spike always facing up
All good makes sense!I guess I should have added that I've never had the stumble with it pointed up, when I had it pointed forward I tried to rejet and adjust the carb several times, and could never get the stumble to go away. I should have been more clear. I've riden in the rain several times and with a rain sock on I didn't have a problem.
