Engine periodically sputs
Phil Baum
Try changing the orientation of your spike air filter. If its forward, point it up, and vice versa....and check if the auxiliary bowl vent screw has been removed? S&S recommends removing it when changing breathers.
The air filter has been on for quite awhile. I'll try changing the direction of it. Let you know..........
FWIW, now that I stop and think about it, the Pit would fart around those same speeds. From what I could figure it had more to do with wind direction. If I ran into a throttle side wind it would cough just once or twice. I haven't noticed it in a while tho....
Weather will play a part in it also. When I had my spike air filter pointed forward on cool days the stumble was worse. Hot and dry days it was not as bad. Always around 65mph. Since I pointed it up I've had no problem with it. You can jet it till your blue in the face, but if you ride in all types of weather like I do the stumble will remain (with the spike pointed forward). This is one of the reasons a lot of people don't like the spike air filter. This is what I've experienced with the spike air filter, hope it helps
Weather will play a part in it also. When I had my spike air filter pointed forward on cool days the stumble was worse. Hot and dry days it was not as bad. Always around 65mph. Since I pointed it up I've had no problem with it. You can jet it till your blue in the face, but if you ride in all types of weather like I do the stumble will remain. This is one of the reasons a lot of people don't like the spike air filter. This is what I've experienced with the spike air filter, hope it helps
Never a stumble for me anymore after I rejetted, unless it's raining hard. Spike always facing up
I guess I should have added that I've never had the stumble with it pointed up, when I had it pointed forward I tried to rejet and adjust the carb several times, and could never get the stumble to go away. I should have been more clear. I've riden in the rain several times and with a rain sock on I didn't have a problem.
All good makes sense!
