you on the ball Slick
At our age that could be a big problemHey, I occasionally fart too so I don't think it's a big deal or a problem...
I'm not real sure, but I don't think farts are supposed to have lumps!At our age that could be a big problem![]()
His problem lies in his Suckdenator......Hey, I occasionally fart too so I don't think it's a big deal or a problem...
Leave it to Chubs to take it to another level, that's fkd upI'm not real sure, but I don't think farts are supposed to have lumps!![]()
Yes. Speed is correct also..........Do you have a spike air filter, is the stumble around 65mph?
My pit has a habit of stutterin at about 60 too!
twist the grip and she picks right up and smooths out.
I kinda leanin towards a fouled suckdenator also!
Already replaced the blowfer valve, and all electrical fluids, with no change.
Yep, it's gotta be the suckdenator!
Ya don't happen ta have 8 or 10 layin around on a shelf, do ya Marky?
P.S. lookin for a red one ta match the frame!
You have to re-route the SUCKDENATOR valve and tube BACK into the frame dammit JIM!!! It's leaking into your fucking CARB now????!! Then re-tune your air/fuel ratio on your carb!!!! Your mechanic fucked up bro!!!!! Get a new mech!My pit has a habit of stutterin at about 60 too!
So, ya think it's possible that the blowfer valve might be installed sideways, causing the electrical conjunctions to plug up the orifices in the frame?? Shouldn't the suckenator unplug that mess?You have to re-route the SUCKDENATOR valve and tube BACK into the frame dammit JIM!!! It's leaking into your fucking CARB now????!! Then re-tune your air/fuel ratio on your carb!!!! Your mechanic fucked up bro!!!!! Get a new mech!
Try changing the orientation of your spike air filter. If its forward, point it up, and vice versa....and check if the auxiliary bowl vent screw has been removed? S&S recommends removing it when changing breathers.Yes. Speed is correct also..........
On a serious note, Harry is correct. I've been running mine straight up for as long as I can remember....if the air filter was just thrown on, and the bowl screw was not removed, it will cause this issue.Try changing the orientation of your spike air filter. If its forward, point it up, and vice versa....and check if the auxiliary bowl vent screw has been removed? S&S recommends removing it when changing breathers.
