Let's go wire by wire, top post1 goes from solenoid to battery positive.
Post 2 goes from the side of the solenoid to the starter motor.
The Spade terminal should be attached to a green wire coming from the starter button.
Lmk if you can see that video. The link you shared earlier the guy said the top post goes to battery +, and the side post just has the solenoid wire so I’m confused… the green space wire is where it’s supposed to be
The wire in photo 1790 should be your ground wire. It connects the frame and engine to the negative post. Current return back to the battery.....in short, provides chassis ground.
Idk I may be wrong, bc this last wire the one in pic 92 isn’t even big enough to fit on the studs on the starter so it must go to battery but does it go to positive or negative?
