BLOWN TRANS ?????
jwoolf
Standard oil in mine. I don't do burnouts or wheelies on the big dog. I do get on it though. I don't think that should snap a mainshaft after around 10k miles though.
The motor mods on mine aren't too extensive but, I have V&H pipes and the massive weber carb set up. There are others here that have had a LOT more mods than I do.
05chop
Where did it snap the shaft at? To get to the root problem we need all the facts first. this opens a whole can of worms.
Fibersnake
Banjo Playing PsychoBilly
Will be interesting to see some of the specifics from those that have had one fail for sure. Jwolf seems to be pretty standard and based on his, nothing that would indicate some way out of line.
On the oil, I know many use the Redline Shock Proof in the tranny, and it does not seem to be a problem, however in my O & M it specifically states that "Harley synthetic lubricants is NOT recommended for use in Big Dog Motorcycles transmissions."
Now what does that mean and how it actually applies in the real world, I have no clue. Do BD mean Harley synthetics or all synthetics?
That said, I use the regular Rev-Tech, but I change it out about ever 5000 miles. Have not had no issues, shifting or otherwise. Doesn't mean it is any better or worse than Shock Proof, but one of my concerns with the Shock Proof is that it is very thick and many would think that being so is better.
My thought is that it may be too thick and when it is up to normal temps or trying to get there, due to higher viscosity, it may not flow that well and actually create more stress on the tranny. Have seen one tranny taken apart that was using Shock Proof and the stuff was so thick and adheared to the internal, that it took quite of bit of deep cleaning to get off the componets. Do not know if this is good or not, but of some concern to me-so I stay away from it.
Just curious of how many that have had tranny failure may have had the Red Line Shock Proof or other synthetics in their units, if any.
05chop
Oil related failures can happen usually shows up in the bearings first.Newer machine surface and clearances are closer too and require syn oil.this oil Carry's away the heat and absorbs the shock better so they say. I run what the manufacture says to run in the oil dept.I have seen in the heavy duty engine like cat that the syn oil is taking out cam bearings since then i went to shell rotella oil. Shear factor of the oil comes in to play with tranys causing hi heat.
monster74
i am the owner of a 04 ridgeback. And i will post some pics soon. I had the same problem with my tranny. In neutral coasting at 35 mph and bam. It goes to hell. And my warranty had just expired.
Now i am looking for a EHC for it and cant find a reasonable vendor after me saving the money because the link i saved is on a forum that no longer exist.
I have replaced bulbs thinking it has been the headlights and then it would not have a low beam or vice a versa. Then it would run for a while and die.
This led me to think i had over heated it or the kill switch was faulty.
Overall i have a bike that has about 6000 miles and is serves as a hole i throw money in. I am disgusted with it no matter how good it looks. If someone can help me find a ehc please pm or paste a link. Thanks jason
jwoolf
That makes 9 mainshafts. I'm keeping track of all of them and who it happened to so far. ( Sul, that was a good idea )
05chop
I don't always need everything explained but in this case we do need desperately to believe there is somewhere an explanation. WTF ?
monster74
:bang: And not to add insult to injury i take it to the only big dog dealer in Arkansas to find out all the bad news. They want 2500 hundred to put in one that is not the same but one like they had already used to replace a guys here i hot springs where i live. I get a buddy to install a new rev tec and I be damn if it dont break that one. The factory doesn't believe it so i send the second one back to rev tec and get a replacement. And i can put installer error in there as a possible reality but after that the ehc thing begins. Also replaced a starter and a new problem with the shifter linkage. It has been a nightmare. :nopity: :nopity: :nopity: :damnit:
Rick
Dud that sucks your bike must have been built on a Friday at 4:00pm
Front Runner
Man, that's not good. Are you the original owner of your bike?
skully
as far as motor mods to my bike; just the standard, pipes and breather add ons. i do put miles on it but mostly with Patty riding with me so there are no wheelies or stupid stuff. with all the aftermarket parts and paint on my ride i don't abuse it, i just use it.
the trans is to be here 3/28. hopefully i'll have "skully" back by april 4th, as we were planning on taking the bikes with us on our honeymoon starting the 7th.
On the plus side, Tampa Big Dog has been good with the warrenty and recall issues. i think if they ever closed up i would be lookin to get ride of the bike. i don't think i would want to travel across the state trying to find a decient shop to work on the bike. i would rather sell this one and just build another custom and keep it old skool in the electronics department.
jwoolf
No help from big dog on this one and, 1105.00 later, I've got my bike after over a month in the shop.
I'm going to get the broken mainshaft and 1st gear back.... I've requested it and, after all, it's mine, I paid for it.
Next major issue and, I'm fucking selling it. I've had enough of this shit.
some people don't ride theirs that much but, I ride mine. It's got to get me from A to B. If it can't do that then, it's not much of a motorcycle.
Fucking blown up transmission, clutch carrier, 5 starters in one year is too much fucking problems. Not to mention that it's been in the shop for about 6mos of that time because big dog can't supply their own fucking parts.
I'm going to hang on to that mainshaft and watch and see what happens. At some point sombody is going to have an accident because of this fucked up part. I was lucky my back tire didn't lock.
P8RIOT
Good to hear you finally got your ride back, jwoolf. :up:
Dare I say, it sounds like it may be time to upgrade. :eek: :D
Vegas
This is exactly the reason I sold my 03 Chopper. Wrecked it and took 6 months to fix and it was always broke besides. Can't blame you man. Sometimes you just don't get along.:D
Rick
An accident will occur and someone will get hurt or killed and BD will finally do a recall. I doubt it will occur un till then. My bike is out of warranty on 4/1/08> I feel the same as Woof, any major issues come up after 4/1/08 and I may sell the damn thing. BD just isnt stepping up to fix the issues with these bikes.
KnotSo
Admin
Jwoolf, It may be better to sell it now while it works, get some decent bucks for it, and get the more reliable 2006-2008 bikes. Lotta great deals out there right now. Just a thought.
05chop
To bad you didn't get pictures of the ends where the main shaft snapped.I wood like to see if the break was from torsional loading metal fatigue
J
JohnnyB
Guest
I had a transy problem today while driving back from the new dealer in Maple Shade, NJ (didn't know they were there until I read their intro on this site). They just did the fender strut recall on my 2005 chopper (nice folks). I was doing about 70 in 6th gear, slowed due to merging traffid, downshifted to 5th and next thing I know it kicks out of gear (no neutral light, just NO GEAR or any gear beside 6th). I upshifted back to 6th and was able to get home in 6th gear (went through lights after I got off rt295 and never slowed down). I got into the driveway and tried shifting again. Nothing at all, not even neutral. I called the dealer they're going to come and get it. I'll let you know what it is after they tell me the problem, but I bet it's the same issue you guys have had. Bad fucking news, and it happen just when the weather's getting warm.
