Bigtrks
Could there be a ground that isn’t hooked up somewhere that goes to all those pensHere you said the wires going to the sensor Red to black no voltage. Red to ground 13 volts. That tells me the black wire from pin 45 to the sensor is open?? Or pin 45 is not connected to ground? If you look at the middle picture in post #64 the dark black pins should all read to battery neg. / ground. Pins 19,22,35,36,37,38,39,40,42,43,44,45,46,47 & 48
