I found it on there waiting for a response from you. Thanks buddy.U tube is your friend.
OK I’m lost then. It has a new speedo and new sensor. It has power. I guess I’ll take a tape measure and count my miles. Lol.Yes
All wires are good no open wires.
Here you said the wires going to the sensor Red to black no voltage. Red to ground 13 volts. That tells me the black wire from pin 45 to the sensor is open?? Or pin 45 is not connected to ground? If you look at the middle picture in post #64 the dark black pins should all read to battery neg. / ground. Pins 19,22,35,36,37,38,39,40,42,43,44,45,46,47 & 48OK I unplug the sensor turn the key to the on position. And check for power active sensor not the short wire off the sensor the other one. I get 13+ bolts if I ground it to the bike if I ground it to the black wire I get nothing. Does that mean the wire is broke between there and the speedometer?
Is there supposed to be aHere you said the wires going to the sensor Red to black no voltage. Red to ground 13 volts. That tells me the black wire from pin 45 to the sensor is open?? Or pin 45 is not connected to ground? If you look at the middle picture in post #64 the dark black pins should all read to battery neg. / ground. Pins 19,22,35,36,37,38,39,40,42,43,44,45,46,47 & 48
i’ll check it out tomorrow. I am off to bed. My alarm goes off in six hours. I did notice today. It would be left side of battery along the frame, a bolt that has a wire eyelet under it and the wires been cut or broken but I can find no wire anywhere, that should go thereHere you said the wires going to the sensor Red to black no voltage. Red to ground 13 volts. That tells me the black wire from pin 45 to the sensor is open?? Or pin 45 is not connected to ground? If you look at the middle picture in post #64 the dark black pins should all read to battery neg. / ground. Pins 19,22,35,36,37,38,39,40,42,43,44,45,46,47 & 48
No, it has the one on the far left and when you touch them together, it says 0 1.3.When you have your meter set to 200 with the leads apart does it say OL and then when you touch both leads together what does it read 00.9?
I am sorry that I am horrible at explaining thingsNo, it has the one on the far left and when you touch them together, it says 0 1.3.
