Compression release
Mickmorris
Well Known Member
There are 2 passages in the head that are involved when the compression release is activated. If the broken release permits leakage , you'll have a super lean condition in that cylinder, which can do piston damage.
John
Thx for that info John. I did not know that. Obviously the solution would be to install a new one. Sounds like the other choices could cause issues to
Wildbill407
John
Ya Im gonna pull the cylinders and check them. There isn't any scoring on cylinder wall but should just take the time and do it right.
john sachs
If you're going to remove the head/heads, you can weld up the small hole in the combustion chamber, and you won't need to worry about a compression leak. That will = a permanent fix.:rolleyes:
John
Wildbill407
Then I will run into starter issues. Then battery, then tore up jackshaft, so on and so on. Don't want to put wimmer sparkplug manuals. Running a bdl 3" open. Considering putting these in instead of s&s.
john sachs
Imo, those releases (pic) are for a completely different set up than what S&S designed to work in their heads, or replace the ones you have. Better check with Twin Power, and when you do, explain that you have the early, S&S solenoid operated releases, that you want to replace.
FWIW, the combo, spark plug style releases are JUNK. :mad:
John
john sachs
I talked to my buddy at Twin Power today. Those releases DON'T replace your S&S releases. They need to be installed by drilling into the combustion chambers of the heads. On S&S heads, I wouldn't attempt to do that. Here's a pic of someone who tried, and missedIMG_0749.jpg
