Wildbill407
Can I plug rear cylinder temporarily and run one compression release on front cylinder.
You may need to fabricate a custom plug, or modify your bad release, or you may wind up with a compression leak. If it were me, I would just install another release.Can I plug rear cylinder temporarily and run one compression release on front cylinder.
There are 2 passages in the head that are involved when the compression release is activated. If the broken release permits leakage , you'll have a super lean condition in that cylinder, which can do piston damage.Why?
Thx for that info John. I did not know that. Obviously the solution would be to install a new one. Sounds like the other choices could cause issues toThere are 2 passages in the head that are involved when the compression release is activated. If the broken release permits leakage , you'll have a super lean condition in that cylinder, which can do piston damage.
John
Ya Im gonna pull the cylinders and check them. There isn't any scoring on cylinder wall but should just take the time and do it right.There are 2 passages in the head that are involved when the compression release is activated. If the broken release permits leakage , you'll have a super lean condition in that cylinder, which can do piston damage.
John
If you're going to remove the head/heads, you can weld up the small hole in the combustion chamber, and you won't need to worry about a compression leak. That will = a permanent fix.Ya Im gonna pull the cylinders and check them. There isn't any scoring on cylinder wall but should just take the time and do it right.
Make sure they are the correct thread before you buy them.Then I will run into starter issues. Then battery, then tore up jackshaft, so on and so on. Don't want to put wimmer sparkplug manuals. Running a bdl 3" open. Considering putting these in instead of s&s.
Imo, those releases (pic) are for a completely different set up than what S&S designed to work in their heads, or replace the ones you have. Better check with Twin Power, and when you do, explain that you have the early, S&S solenoid operated releases, that you want to replace.Then I will run into starter issues. Then battery, then tore up jackshaft, so on and so on. Don't want to put wimmer sparkplug manuals. Running a bdl 3" open. Considering putting these in instead of s&s.
