No with the key off you should not have any lights. Was the headlight bright with key on? If you can ohm out the key switch.I charged the battery overnight and put in the bike and the same issue happened. A strange thing is even after I take the key out all the LEDs are lit along with my oil light neutral and high beam.
You guys really think it's the battery? I might as well go ahead and order one. Anybody have an Amazon link. Or I could drive over to my local Harley shop and get one there.
The old battery was bad. With a new Harley battery all the lights come on but you cannot switch to hi beam or make the blinkers or brake lights blink but they come on. Also I still have all the red leds light and even after removing the key the red leds stay on. I remove a battery lead to shut those off. But the slam button will turn the bike over, but will not start. man, wtf?Maybe put a jumper around the key switch to see if it makes any difference.
Littie, I rather attempt the refire with said parts. It be fun scratching my head. Correct voltage did not change things. BD did not have a LED reading tree as far as lights on. You're most likely stuck with the historical field fix.Wow, an original 04 EHC. You got your money worth out of that. Considering they were recalled back in 05. I've seen a couple come through my shop. Go ahead and get ahold of the Kaptin. He has the perfect replacement for it.
www.wildsteedworx.com
You may have had a short in your battery which took out the EHC. If your getting an ignition fault light that's why your bike won't start. The slam button just makes the starter run. Look for broken or chaffed wires all over the bike, any place you can access and see. If you have no success troubleshooting make sure you put a fuse or circuit breaker between the battery and the new EHC before you attempt to start the bike. If you don't and the issue was not resolved it could very well take out the new EHC.The old battery was bad. With a new Harley battery all the lights come on but you cannot switch to hi beam or make the blinkers or brake lights blink but they come on. Also I still have all the red leds light and even after removing the key the red leds stay on. I remove a battery lead to shut those off. But the slam button will turn the bike over, but will not start. man, wtf?
With the key off look behind the coil and unplug the key switch itself from the harness and tell us if the lights on the ehc are still lit or not...im curiousThanks guys for all replies.
I'm bummed and burnout from searching for a bad wire. My headlight was just replacing the the 3 connectors and bulb and I'm confident that is not the issue. It is very strange that the ehc is still lit even after removing the key. I wish there was a way to know for sure if the ehc is dead, damn 550$ for a new one. This may end my riding season early.
Yes the light bulb is out and no change on the LEDs. I'm going to slowly start going and pulling it out and send it to Wild works. That is an awesome idea. Once I get it out I will give them a call. Thank you guys I really appreciate the help on thisJust one more try , start with the headlight and disconnect the bulb. Then look for a change on the EHC fault lights for clues. Continue to other connectors on the bike and look for change as well. The reason I'm harping on the headlight is because it has the capability of pulling down some high current which may have caused your battery to retire. Knothead's idea is excellent because somehow that circuit is holding when the key is off.
After your exhausted and wanting to order the EHC first pull yours out for a careful look at all the wires and pins. Also if you remove it WildSteedWORX can test yours before you buy the new one. It's like a $46 dollar insurance policy against you buying an EHC you didn't need.
Search : WSW, Rule Your Ride!
WSW : Search - BIG DOG SERVICES and REPAIRS BIG DOG MOTORCYCLE PARTS big, dog, motorcycles, parts, shop, online shopping, storewildsteedworx.com
I'll let you the results. Thanks knotheadWith the key off look behind the coil and unplug the key switch itself from the harness and tell us if the lights on the ehc are still lit or not...im curious
They look pretty simple to install. I bet I could do it!Sorry to hear that. Yes sounds like a new EHC is in your future.
Bin there done that. wildsteedworx
Its very simpleThey look pretty simple to install. I bet I could do it!
