hi did you find someone ? now im loking for mechanicCan anyone recommend a Big Dog meachnic in Illinois. Preferably near chicago?
What's wrong with the scoot?? There's lots of knowledge here on the forum I'm sure someone can help you outhi did you find someone ? now im loking for mechanic![]()
Did you get some bad fuel? Has it been setting awhile? Plug wires seated good on both ends? Maybe you should start a new thread.hi Dusty when i start the engine i think one cylinder working only and backfire
Thanks! I live in Akron, OH. I had no idea.Ohio-(Jack) from Straight Shooter Custom Cycles (330)671-1258
There is 46,055 square miles in Pennsylvania. Can you narrow it down a little?I call this one bullshit, I live here to:lol::lol:
Well if it's running on one cylinder only you should definitely know. They sound like shit on one cylinder. Do you have a dual outlet exhaust? Stick one hand over each exhaust port if so, not for long, just long enough to feel heat. If one isn't hot enough to burn your hand that cylinder isn't firing. Alternatively, you could pull a plug with the wire attached and stick it close to metal and bump the starter. You'll see a spark if it's firing properly. Also if you're familiar with a dmm you can test for voltage at the plugs then at the coil and further on back until you figure something outhi Dusty when i start the engine i think one cylinder working only and backfire
JAMIE'S CUSTOMShi did you find someone ? now im loking for mechanic![]()
I only live in 1There is 46,055 square miles in Pennsylvania. Can you narrow it down a little?
Hi nine lives i just bought my second big dog ! Its an 06 pibull and im having an issue with it startng ! It will turn over for a few seconds then guage will go out and light will weaken and starter will act like battery is dead but its brand new 310 cca with a full charge ! It did same thing with ooriginal battery ! HELP !PA, me.
