Will do when I get home. Not sure about the inline gas filter. Will gather that info later tonight after 8.I turned the petcock off and removed the gas line and used a rag to catch the gas, I also removed the brass hex on the bottom of the bowl to empty gas from that also. Then remove the screws and slowly lower the bowel. You should be able to read the numbers on the inter and main jet with a mirror. By the way do you by chance have an inline gas filter? Is the gas line one solid piece from the petcock to the carb.?
Btw I appreciate this help you guys are giving me.
