francoblay1 The Spaniard Jan 23, 2015 #101 then if you have a stable at about 2500-3000 rpm.. will talk about the Air Bleed Jet. EDIT: Forget about this for the time being.
A AZBigDog Member Jan 24, 2015 #102 francoblay1 said: You haven´t answer yet about your Inter jet... what size is it???? Go with a 31. :up: Click to expand... Where can I find the size of that?
W woodbutcher Mr. Old Fart member #145 Staff member Jan 24, 2015 #103 should be stamped on the jet itself. otherwise, might need to get a set of wire gauges.
A AZBigDog Member Jan 28, 2015 #104 Seems to have cut back with adjustments to carb. will play with some more when I have a day off.
