BroadBand
Since late 60's
EHC problem electrical issue
This is one post I hoped I would never make... :bang:
I need some help in figuring out which direction I should take. About two weeks ago my o4 chopper cut out, went dead like the key was turned off. All electrics were still OK. Waited maybe 2 or 3 minutes, recycled the key off/on a few times, it started up to go a couple hundred yards to konk out again. This time I removed the seat, everything looked OK (circuit breaker NOT tripped, no obvious broke or chaffed wires), I removed the gas cap (thinking vapor lock or no gas) and had gas. Lights, turn signals and horn all operate.
It fired up and ran just fine the rest of the short trip. Saturday afternoon, it cranked and cranked but would not start at all. I keep it on a battery tender all of the time it is not moving. Pulled seat and did not have any lights on the EHC. I pulled the air cleaner and a twist of the throttle sprayed gas in the carb as it should. Since it had gas the next thing I checked was whether it was getting a spark. I pulled both plugs and touched them to the head bolts as I cranked the starter. No spark at all. Put everything back together, attached the battery tender and called it a night.
Next morning I pulled the seat and turned the key and I had lights on the EHC. Hitting the RUN button lit up another light and it started just fine. Gotta love the “self-healing” aspect of these Big Dogs.
I thought then to test it with a short 10 mile round trip. At 1.6 on the odometer it died. I pushed & coasted back towards home. So as I pushed up a grade and was just out of breath and popped the seat to see the EHC, turned the key, everything lit up, started it up and rode the rest of the way home. So it had maybe a 15 minute rest or cool down and it started up again. Back on the bat tender. The next day I took out the battery and had it load tested. Mechanic said it is OK fine. Damn, I was hoping it was toast. It was new last riding season.
I am thinking to dump BD electronics at this point. I don’t have the testing equipment to test the cam sensor and I am unsure of the procedure (as explained/posted on this forum) to bypass the EHC. It has a recent upgrade with the HID light from Jake. That was a no brainer. And if something goes wrong with the headlight, can it take out the spark to the plugs? That seems crazy to me but after reading a lot of the posts – just maybe??
How about it guys - What am I over looking? Which way should I go now?
