Battery (+) to fuse.
Fuse to toggle.
Toggle to coil.
Coil to cone.
Ignition done.
_________________________________________
Fuse to brake switch wire.
Other brake switch wire to stop bulb wire.
Brake light assembly is grounded say. Or other combo setup if ground wire is used as ground, not the brake housing to fender to frame is ground.
Only use one brake light to the most [pedal] used, or get slammed from the rear.
Brake light done.
Toggle switch to hot side is ready for ign and running lights.
Run a wire up and back to the head and tail light. Tie that with the coil wire off the toggle. Lights come on the same time as ign.
Run the high beam wire with a male end. Have the low beam's end with the same male fitting. Light blows? Pull over, swap male wires and on down the road you go.
Running lights done.
_______________________________________________________________
Take a jumper band, tie a 15a fuse to the brass side of the hot side of the main fuse's brass side.
Take a wire, send it to the winker relay.
Tie left and right winks to the bar's left and right switches. This will take a more detailed wire layout or trump the winkers on and use hand signals. No wires to the winks.
Winks done.
Bottom line:
A. You have 2 fuses, 1 toggle switch, 1 stop switch.
B. You don't have; horn/starter relay/start button/start wires/winkers/winker relay.
C. You have a push button at the starter. You have running lights, brake light, spare headlight, fake winkers.
Options:
Winkers/Horn:
Take an old feeler gauge(s). Bend the end so it has a slight V to it. Set a ground wire to the other end of the feeler. Zip-tie the feeler gauge so it is suspended off making any metal contact when mounted. You now have 3 blades for the right/left/horn buttons. All you are going to do is push the bent V onto the handlebar, make ground by completing that circuit. Your fingers pressing that individual blade are the horn and winker relay stabbings, so [manually] tap like a relay.
Home he don't need no switch is just a stab at the spring steel kind of kill switch.
