Newbie here to the BD world and have a few?
Nelly4570
Alright guys, got under the tank to take a look at the wiring, not as bad as I thought. The JST connector that goes to the led cluster has two wires pulled out and they will not lock back in. I’ve spread the wire clip and tried both ways. New connector or push back in a super glue wire to connector…….
Snuffy
I would use new connectors but thats just me. Finding the problem is the hardest part.
Mickmorris
Well Known Member
Don’t be to upset if when you change the connector that the cluster still doesn’t work. None of those work on my 2000 even though everything else works & looks perfectly fine. I am just guessing but you own a ‘04 mastiff?
Nelly4570
I’m going to test the pinouts today with power and verify before I go any further. I’m unable to find just the connector itself, only the harness. 04 pitbull
Nelly4570
