Yes, it didnt have oneYou probably know but be sure there’s a fuse between EHC and battery
I would use new connectors but thats just me. Finding the problem is the hardest part.Alright guys, got under the tank to take a look at the wiring, not as bad as I thought. The JST connector that goes to the led cluster has two wires pulled out and they will not lock back in. I’ve spread the wire clip and tried both ways. New connector or push back in a super glue wire to connector…….
Don’t be to upset if when you change the connector that the cluster still doesn’t work. None of those work on my 2000 even though everything else works & looks perfectly fine. I am just guessing but you own a ‘04 mastiff?Alright guys, got under the tank to take a look at the wiring, not as bad as I thought. The JST connector that goes to the led cluster has two wires pulled out and they will not lock back in. I’ve spread the wire clip and tried both ways. New connector or push back in a super glue wire to connector…….
I’m going to test the pinouts today with power and verify before I go any further. I’m unable to find just the connector itself, only the harness. 04 pitbullDon’t be to upset if when you change the connector that the cluster still doesn’t work. None of those work on my 2000 even though everything else works & looks perfectly fine. I am just guessing but you own a ‘04 mastiff?
Thanks! The harness from HDM is $24. I’m trying to find out what voltage that PCB works at to test. I’m sure the ECH drops it to low voltageHere is all I could come up with. They may work with ya?
If you end up with the new EHC, you will have a new connector with the new harness. Just a thought.
