I’ve soldered back all the wires that were cut on the harness and repaired. I’ve tested the right pcb board and it is bad (reason they installed push buttons) I want to go back factory so I’ve ordered new pcb’s. I want to get them installed and then hook up power and see what EHC does and thunderheart, go from there. It appears that someone has installed the new recommended harnesses from the upper to under the tank going by what I’ve read. I will pull the tank after I see what it does and what the lights tell me. I think I’m on the right track lol
