K9 Rebuild/Upgrade
82ndAirborne
Looking awesome!
Can’t believe you scored an air shock, that’s great!
Me either! What was really great was getting 2 full sets. The compressor is new, but the Shocks are used (Slightly), no warranty, but with two sets I should be OK. Ordered a solenoid and air line from Donna, so I think I can do the installation. Also scored a Maltese Cross Derby Cover (picture 1). Sadly using the last bottle of my good polish...man I love this stuff. A shame you can't get it anymore. So today I'm polishing up the new cam Cover and replacing my new Ignition Cover that I somehow scratched (slightly). That will be all until next weekend. Hopefully I can get started on the Inner Primary replacement. After that...really close!
82ndAirborne
Oops...I accidentally sent a picture of dye that I'm trying on the Spike Air Filter. I don't think it's going to work because the Filter is not cotton based...Metal I think.
82ndAirborne
Question: I read somewhere that if you connect the Circuit Breaker up backwards it WILL NOT protect the electrical system. Does anyone know if I've got mine wired correctly. I see that one of the Circuit Breaker posts is made of copper. I assume this is done to assist in proper connection.
82ndAirborne
Ok...here we go with Primary swap. So, I'm looking at picture 2, I would like to remove the clutch basket as a single unit.
(From my manual)
CLUTCH BASKET/ENGINE SPROCKET/PRIMARY CHAIN-REMOVAL AND INSTALLATION
I see a Retaining Ring holding the Throwout bearing. The manual skips right over removing this and goes straight to removing the clutch hub Nut. I assume this is a simple oversight and I'll find the nut behind the bearing. Is this correct?
82ndAirborne
Little help...I'd like to remove my clutch basket as a single unit (not disassembled). How do I start this process. Do I remove the 4 Hex Bolts first, or the Retaining Ring and Bearing??? My manual doesn't match...it shows the Clutch Hub Nut first. I don't see the nut...I'm assuming it's behind the Throwout Bearing.
SKOGDOG
One of the old ones.
Working from memory (in my case perilous territory). I’m sure to have missed a point or two but you’ll figure it out if no one corrects. Loosen all clutch adjustments and remove clutch rod. When reinstalling coat rod with lube (bearing grease).
1. Remove #11
2. Remove #12 Get the little stair step locker and secure the primary chain—loosen the crankshaft bolt while you’re at it—a quality impact wrench is useful here. Don‘t ever attempt to use the elevated ‘pins’ on the inner hub (20) for leverage—they’ll snap.
3. Loosen #23 (left-hand thread) With both crank and clutch hub nuts loosened, remove the primary chain adjuster.
4. Remove the four #18 bolts I usually remove the friction/steel plates using a couple of magnets. Easy peasy.
5. you should be able then to take off the crank and clutch bolts and remove the clutch, crank drive pulley and the chain all at once
6. you’ll find two threaded holes in the rotor housing—find two bolts (I use stove bolts) and then pull (fight) the rotor magnet-do NOT strIke or drop the rotor
7. Treat the small stator bolts gently during re-assembly. The stator wires simply unplug.
8. When re-installing the wiring thru the primary housing, use a high quality RTV and cure for a day or two. Clean it obsessively inside and out or it’ll leak. I use brake cleaner.
While it’s apart you can check the clutch for stack height (1.97”for total) I think. Some have had issues with weak disc springs. I think a better one is now available if you’ve had any slippage and stack height issues good.
82ndAirborne
1. Remove #11
Wow!! Excellent. That's exactly what I needed. I'll be installing everything new inside. I have it all now, except for the clutch parts. I'll decide what I need after I take it all apart. I read an earlier post about a Hardened Clutch Hub Nut available through BAKER...I'll get one just to be on the safe side. I've got two of those Stair-Step locks and a really good Impact gun. I should be OK. I've been doing alot of research and watching videos on the procedure. Really appreciate these instructions.
82ndAirborne
I got started on the Primary today. So far everything is coming apart without much trouble. However, I see great Oil (transmission) oozing out from the bottom of the seal. Not good. Question; how difficult is it to replace?
82ndAirborne
So, I got it off. I thought I had a transmission seal kit but I only have the belt/Drive gear side. I'll have to order the clutch side kit. All I can do for now is get everything cleaned up and prepared for the installation. I'll try to at least get the new Rotor/Stator installed. I'm going to Kentucky for 3 weeks so everything will have to wait until I return. I'm going to take my stock Grips along with a set of Accutronix Tribal Grips, and see if the machine shop can make me a set.
SKOGDOG
Huh—-my K9 also leaks a dribble of trans oil when I pull the clutch but my trans never requires any oil to be added. See if there is any end play in the input shaft—it should be rock solid. Check your trans oil level. Im in FL this weekend and don’t have access, but I think the clutch inner hub is sealed by a rubber inner lip on the transmission seal. When you remove the hub and spline (#21) from the transmission input shaft, it allows a bit of oil to seep out. Bet $10 your trans input seal is ok and the seepage normal.
82ndAirborne
I'm thinking the same thing. I've NEVER had to add transmission fluid between changes. Also, the seal looks in really good shape. I'll look on the back side of the hub when I get back over there. I went ahead and ordered the seal anyway. Oh...I checked the shaft, it's in perfect condition, no play and rotates smoothly.
That Stator Plug looks like it's going to be a real SOB to get in. I ordered some really good sealant...hasn't arrived yet. It's used on aircraft so it should do a good job. I'd hate to do all this only to discover a leak. So...another $50 bites the dust! Hahaha
Sent another small package to Space Coast yesterday. The Maltese Cross Derby I bought had just been rechromed, but looked like someone used a sanding disc on the flat center area where the Cross Mounts. Also, I want to replace the black rubber vacuum hoses on the carb with braided steel so I needed to get all the Band/Spring Clamps chromed. I got a new check valve that separates the hoses from S&S. So...I keep telling myself "Almost There!"
