Inner Primary Leak
KeepingItAlive!
I have a very small inner primary leak on a 2006 BDM Pitbull. Has a Baker 6 Spd. Any idea on costs to put a new bearing in? I am looking for a ball-park before I call mechanic (probably Stroker in DFW). Thanks a lot.
SKOGDOG
One of the old ones.
Bearing seal maybe, but hopefully not the bearing. Also could be a seep from the starter motor. Once I had a transmission output seal seeping and the oil ran downhill across the frame with the bike leaning on the kickstand and spotted the floor under the primary. Clean t up real good and try to pin it down.
mleach72
How much fluid are you putting in the primary? The manual says 1 quart, but that can cause leaks and starter problems. Most run 20 oz. I had an open primary put on my bike because I got tired of fixing a primary leak every other year. Later on, I found out that it was probably too much oil causing the leaks.
blacktopper
[/QUOTE
try to locate the leak , is it leaking around the starter or where the crankshaft goes thru the primary?
KeepingItAlive!
1 qrt like the maual said. But 1 qrt exactly. I'll take like 4 to 6 tablespoons out and watch it. Thanks for the tip!
Thank you @kickstart . I'm not sure if there is a vent but i will definitely look into this. I have the book of CAD drawings of all the parts and systems of the bike. I'll also have Strokers confirm before they dig into anything. Thanks!
They should know about the 22ozs of fluid in those slim primaries, but remind them and tell them where you heard it.
kickstart
Just look between your engine and trans at the inner primary. They can get clogged and need cleaning be careful as it's only a 10-24 or 32 can't remember when replacing. Curtis has them if needed.
