Thunder max 309-340 exam
Ribert R
When you hit the start button, does it spin at normal speed or is it slow?
Tell you the truth it is hard to turn over with the Deka 310cca.i take the plugs out it turns over great and the compression will blow your hat off, blew mine off. I have a different batt, Fixin to go see if it’s charged get back to you .when I hit the starter button it wants to but I don’t think the battery was strong enough, it has hellacious compression
Mickmorris
Well Known Member
Are the CR’s working? A Deka should spin it over no problem…
