This is verification. I can't overemphasize the importance of circuit protection. If you read through the posts, you can see where mistakes were made and the EHC failed.Not sure what EHC you installed. Here is a schematic of Axel's
EHC replacement
...Just an other story: I got my Ridgeback 3 days ago :) I already kicked off the original EHC (It was not very complicated as the screws were hanging at the holder and the box was separated alreday from the screws) and installed my EHC. Nice bike and more comfortable to ride compare to my other...www.bigdogbiker.com
Did you go direct from the battery for both the VR and the EHC? Neither from the CB ?If you look at the wiring diagram for that bike, both the starter relay and CB are there. The wiring diagram displays both. You can figure well over 100 amp draw on that starter on that engine.
In fact, the CB on the diagram displays 40 Amp for 2008.
Yep. Sure they have a similar device on the board.I suppose the safest idea is to put a diode directly on the solenoid. That was how we rectified the problem on the Shovel.
I see on some of the original schematics it shows the EHC connects direst to the battery. On the RIP kit EHC it had the power labeled to CB. I did install a 20 amp fuse between the two. I hope this will help in case of an issue. Not exactly sure if a 20 is correct ? Could maybe even go lower? I really don’t know.The circuit breaker protects the Battery from a short or an over-current from the VR . The EHC connects to the battery and on a stock bike is not protected from a shorted battery. It is advised to put an additional CB or Fuse between the Battery and the EHC . Consider the possibility of the the Charging system working fine and the Battery shorts out. The original CB wont blow but your EHC will be toast.
That is exactly the correct set up. Circuit breaker is basically eliminated from the setup and the 30 amp fuse from VR to battery is the replacement for it. As I mentioned earlier your EHC positive lead with 20amp fuse directly to positive post on battery. DO NOT put in the circuit with the VR. VR & 30amp fuse directly to positive post on battery.Well right now what I’m gonna do. Is fuse the EHC and fuse the VR. 20 and 30 amp. The directions with the RIP kit has the power to the EHC coming from after the breaker. I can only assume that they planned this correctly as far as voltage concerns. There is NO starter relay with this system. As far as diodes go , I have no idea how to figure those equations. Not even sure how much draw the EHC needs to work. I do know the CB is a 40amp. The other EHC that was in here before was a birds nest mess. Not sure what system it was. Obviously not a good one. It died for whatever reason. If anyone knows how to figure the correct amp fuse for the VR and the EHC from Big Dog please chime in. Otherwise I’m going to at least try this for added protection.
So ,,, NO circuit breaker! ? Perfect timing , I was just wondering about this elimination and was getting ready to head outside to finish allThat is exactly the correct set up. Circuit breaker is basically eliminated from the setup and the 30 amp fuse from VR to battery is the replacement for it. As I mentioned earlier your EHC positive lead with 20amp fuse directly to positive post on battery. DO NOT put in the circuit with the VR. VR & 30amp fuse directly to positive post on battery.
Well as long as you put the fuse in leave the CB. It won’t hurt anything certainly. Just one less piece in the system from my perspective. I took it out. Redundancy.Agreed. I’m going add the fuse for the VR anyway I’m conjunction with the CB since I have it already. It definitely won’t hurt anything. That way if the CB fails I’ll still have protection. Maybe overkill but I’m ok with that.
That’s the problem with the CB is it’s resettable. Most people just push the reset and don’t look to see what caused it to trip. If a fuse blows. You are going to start looking for a problem straight away in your charging system.The original 40 amp CB connected to the + terminal of the battery can remain. All you need to do is add a 20 amp fuse between the + terminal and the EHC. The 40 amp CB protects the Battery from a short or over-current from the VR. The 20 amp fuse protects the EHC from a shorted Battery. If you choose to replace the CB with a fuse it will accomplish the same protection. I don't see the need. The stock CB is re-settable.
No need for it with the 30 amp fuse truthfullySo ,,, NO circuit breaker! ? Perfect timing , I was just wondering about this elimination and was getting ready to head outside to finish all
This up
