No starter relay needed?
Mickmorris
Well Known Member
Will do!!! Thanks !
In this picture you can see the fuse close up by the top of the battery is the inline fuse on the positive EHC lead. Down lower in the battery box is the connector for the VR its a single post with a 30 amp fuse coming out to the battery. The fuse is ziptied to the old ignition module mount. You can just see it below itIMG_3062.jpegIMG_3061.jpeg
Savage 1
If you look at the wiring diagram for that bike, both the starter relay and CB are there. The wiring diagram displays both. You can figure well over 100 amp draw on that starter on that engine.
In fact, the CB on the diagram displays 40 Amp for 2008.
Mickmorris
Well Known Member
What gauge wire did you go with ?
If you go to bigdogpartskingpin.com and put in the information of your motorcycle. Select electrical from the menu for your bike. You will find the VR protection kit. It is like $20 but will save you from ever cooking your EHC again if the stator or VR fail.
Mickmorris
Well Known Member
40 or 30 either is going do the business.
Jimmyb
Yes I saw that. I ordered a 30 and a 20 amp from Amazon. Be here tomorrow. I hope to wrap all this is and cross your fingers for me that all the connections are good the first time routing through the back bone is NO joke. I’m using thermal, tape and electrical tape over top of any areas where the wires will vibrate and rub.
Mickmorris
Well Known Member
:cheers: :chopper:
Jersey Big Mike
100K mile club
Use this instead -- better protection. https://www.amazon.com/Braided-Mana...&hvlocphy=&hvtargid=pla-4584413755313521&th=1
get whatever size or sizes you need.
Jwooky
Thanks for saving us Jwooky!
Just for my own knowledge going forward......what stops the back EMF created by the solenoid from traveling back to the ECM?
I ran into this problem on the good ole Shovel heads back in the day. Any coil or inductor causes this issue when the current is cut.
Is there an inline diode or is it built into the driver?
Thanks Boss
There is nothing to stop the back current per se, you just have to size the drivers etc to tolerate it.
Jersey Big Mike
100K mile club
For the starter circuit there is protection built into the EHC according to the schematic in the manual.
If you want to be extra safe get a relay with protection built in -- harley uses them in older softails.
if you need to know the part no let me know and I can find it pretty quick.
Savage 1
Thanks, appreciate it. No need to post part number Bud.
Do you have a copy of the EHC schematic? I haven't seen that.
Rottweiler
Not sure what EHC you installed. Here is a schematic of Axel's
