Well Bike was delivered Friday morning at 2:30AM. (Driver asked if I needed to wait till morning but being like I kid I said no I will wake up or stay up. Ha) So best biker buddy & my self drank & waited in garage. Good times. Fired it up & drove it down the street & back at 250am haha.
Friday cleaned the bike, chrome, paint, polished triple trees some. Checked fluids. Stator plug in case was leaking so some make a gasket there. Seems to be the main leak. Ordered black seat ASAP, will be here Wednesday. Pics are with my chopper seat as I hate the tan seat (will sell that one). Rode it Sunday, put 15 miles on it & all seemed ok. Kicks stand is bent bad & cracked.... tires are like new tread wise super old date wise & front has cracking onside walls. Dad showed up to check it out & I invited him to ride (kind of the point of having second dog, let him or brother ride & have spare toy/ project) he jumped on it. So, we rode 50 miles met up with my main riding buddies for lunch & a beer. Then to swap some parts, from another buddy's bike (chrome intake vs black spike) & back home. I put chopper up, & I took Boxer back out for a few more beers all no issues other than known ones.
Was told brake lights don't work... they did when got bike after charging battery. They stopped once riding again... loose wire, ech, who knows. Same with Left turn signal, but right works still. I Did check and status is making power once running 14.5V at battery so its making power.
Everything else seems to work fine. Low, Bright, start, stop, Running lights, and horn. I do not see any base gasket, head gasket, or rocker box gasket leaks. Trans, I think is not leaking too, if anything I may have a inner primary leak but also could be that same plug not sealed more examination today after putting 65-70 miles on it after cleaning.
Chrome wheels have some pits/peal spots but can't see from 5 foot away, Motor wise chrome is good, one spot on primary that's bubbled. Bike has more Chrome then polished vs my 04 chopper. Timing cover, calipers, Fort tubes, rims, play holder, ect all chrome.
So far I have already done the Flipped Tag bracket mod (drilled 4 holes and counter sunk screws, adjusted controls to my liking, lowered rear all the way, Swapped intakes from a Miss matched Chrome 90 and Black spike, to Chrome 90 with Chrome Flatt nose.
Today will get a set of riser Bushings on order (they are loose), check for leaks, got a new front tire on order already, and adjust belt as its looser then I would expect (never had belt driven bike), but when you lift off throttle/ down shift it chirps. Other wise makes no noise. Check wires for brake light power and stuff. Probably some Blue plug wires as the yellow is out of place.
