carefreeinaz
I've been through 4 starters until I started following these instructions.
Sent from my Pixel 3 using Tapatalk
Drop the primary cover & take a look. Sounds like you need to replace the jack shaft assemblyWell the saga continues. The starter just spins and won’t engage. I am afraid either the starter or the flywheel is stripped. Battery is good. Starter is still weeping primary fluid. Lesson learned ( no one say DUH !! please). If the starter is weeping oil and intermittently grinds on a start, don’t start the bike, fix it. Never pulled a starter before but there is a first time for everything. This is a new starter with the billet head. Mechanic installed. Any suggestions?
Actually it’s pretty easy. Theres a seal on the inner primary cover that might be bad which I would think might let primary oil into the starter. Just a thoughtShit. That doesn’t sound good or easy.
Thanks. On the rack the phantom goes.
Your symptom sounds like a drive clutch.Well the saga continues. The starter just spins and won’t engage. I am afraid either the starter or the flywheel is stripped. Battery is good. Starter is still weeping primary fluid. Lesson learned ( no one say DUH !! please). If the starter is weeping oil and intermittently grinds on a start, don’t start the bike, fix it. Never pulled a starter before but there is a first time for everything. This is a new starter with the billet head. Mechanic installed. Any suggestions?
You sure it’s not your neutral switch wire?Ok starter gear and wring gear are both chewed up. Erik kindly offered to rebuild the starter. Call in to Baker on getting a wring gear or the basket. Biggest problem I have : Any one know where the ground wire coming off the negative terminal of the battery terminates. I have a ground wire from the battery to the starter but I have a much longer wire that doesn’t appear to be terminated anywhere I can find. Both are the same gauge. , ( yes I took it off to get the starter out, yes I didn’t take a pic of that removal and yes I admit to my stupidity. Just thought I would get that over with). On an 06 Mastiff, the manual says it terminates on the transmission. Damned if I can find that point. I was told there should be only one ground wire terminating at the starter on the mounting bolt. I know my old mechanic told me that due to heat damage on the old wire terminals they added a second ground. I would ask him but his cancer has him tied up for a bit.
Short version. 06 Mastiff main ground where does it terminate? Battery to where?Can’t find it in the manuals. Does it terminate at the starter mounting bolt or the transmission. Second question, if you add a second ground where is the best place to terminate it. Jersey Mike and I both believe at the starter mounting bolt but this wire is too long and was terminated somewhere else. Any ideas ?
Most likely grounds to the frameyes, it is a heavey guage ground wire coming off the main negative terminal on the battery.
