Your starter contains no oil. only sealed bearings.If there is oil that looks like it’s coming out of your starter which is under your oil bag, That’s where the oil leak is either one of the lines or a connection to one of the oil lines Over or near your starterHow to fix
Here is a link to the Billet Starter has a good description on the part with some good info.Well I new there was no oil in the starter yet if I ask the right question it might return the right answer
I checked the primary and it was over filled
Thanks for the right direction
Also I am interested in the up grade starter
Thanks
Rase01
You to Guy! Welcome from Florida! Ride Safe & Be Safe! CheersThat is some good information I am ordering my new starter today
thanks you guys ride safe be safe ..
Welcome from NJWell I new there was no oil in the starter yet if I ask the right question it might return the right answer
Thanks
Rase01
Sorry to be a downer but did you pull the starter and look at it first? With all the potential leak spots on the inner primary it is possible, even though you took great care putting your bike back together, that one of the O-rings didn't seat well. Or the vent got clogged and forced the fluid up to the starter or out of a seal. A new starter wont fix a leak. I would only replace or rebuild it if it got trashed by oil getting in. Just dirty is not trashed. A starter can be cleaned if it didn't get fried and you obviously have the skill set to pull the starter apart.Thank guys, I just had my transmission rebuild by Curtis at WSC , Awesome service , I replace all the o-rings , on both sides of the primary covers , new starter o-ring “4-side” , FYI if anyone out there thinking about this : take your time, be sure to line up the back primary case with the engine and transmission before you tighten down the transmission don’t forget the shims that were underneath the transmission “if any”, this help aline both drive pulley .. belt side,
After I completed assembling the transmission primary cover and It took about three times longer them most ... I added 24 ounces of oil in the primary case and filled the transmission with 20 oz. , I left it overnight , no leaks , took it for 30mile ride this morning, ... oil coming out from round the starter , that’s why I just ordered a new starter and I hope this solves my the problem .
I had to laugh at your " fat head underneath that chassis" comment. Can't hurt to have a nice new Healthy Starter in these bikes. Of course keep the old one as a backup. I blew the small gear inside and having my old cracked housing starter sitting there for parts made it a no hassle event.I hear you my brother but no , I put my fat head underneath that chassis and looked at all the back side O-rings between the engine and the transmission, it’s not leaking from any O-rings at all.. it is definitely the starter ..the Bike has 15,000 miles on it and the starter has never been rebuilt and I think the seals at the jack shaft is going bad and I got oil coming out of the starter I believe it’s time to replace the starter and with this new billet nose cone that these guys offer maybe it might be a time to do this I don’t like oil dripping all over my driveway ,
Check your little breather screen on your primary. Mine was plugged up and I didn't even know it was there. I went through three starters.My 07 k9 is leaking oil from the starter
Yep you sure found the problem. My manual says 32. I have found 32 to be the correct amount in my services. I seriously don’t think 18 is nearly enough.Hey you guys , first of all thanks for all the advice , I believe I found the problem to my oil leaks , it was coming from the starter , The solenoid starter housing was cracked at one of the mounting bolts to the nosecone , and I was wrong , the starter is a rebuilt starter from BDM , My new starter should be here in a few days once I install and take it for test ride, I’ll let you guys know how it go’s , i’m still a little confused as to what is the accurate amount of oil to put in the primary case the 2006 and 2007 owners manual says 32 ounces , other bloggers I said 24 to 18 ounces that is a wide range .....
Ride safe stay safe
