WSW Also has a replacement for the Thunderheart and they will install the correct connectors so it is plug and play.
IGNITION MODULE 2004 OLDER DUAL FIRE DYNATEK NOT OEM [170-00251] - $399.00 : WSW, Rule Your Ride!
WSW IGNITION MODULE 2004 OLDER DUAL FIRE DYNATEK NOT OEM [170-00251] - Original Big Dog OEM 2004 and older dual fire ignition modules are no longer available.WSW preps the Dynatek module to be Plug N Play for your BD. Once you make you rpurchase email us a pic of your current Thunderheart...
wildsteedworx.com
