Need some help with clutch
Hello
i got a 2005 ridgeback with an 117 S&S sidewinder including a balancedrive
when i,m really hanging at the throttle the clutch slips a bit.. and i can feel at a stop that the clutch is still engaged a tiny bit..
resulting difficult neutral etc etc..
i adjusted it already several times but no luck..the clutch is probably worn..no big deal..
but i live in holland and the shops here don,t have those parts on the shelf..or the knowhow wat parts i need to replace the lot..
so my question is:
Can somebody make me a shoppinglist for the needed parts like: primary seals oil which clutchpack etc. and best place to order.
i would be gratefull already thanx
Greet Tim
ps: sorry for the spelling...
Sounds like your clutch pack is worn. For a shopping list you’ll want: full clutch pack (Barnett or Rivera/Primo for S&S/BDL setups), primary gasket set, new primary fluid, and check the hub bearing while you’re in there. J&P Cycles or Drag Specialties are good sources that ship to Europe.
