Ya, drink about a six pack and take a nerve relaxing pill or do a joint. Then try to twist off the outer ring using a rubber pair of gloves. When that doesn't work take a rubber mallet and hit the outer ring until your arm is sore then go back to the rubber glove. :bang:
In a few days when you get the outer ring off you will see a second ring on the inside. Get your rubber mallet and a BIG screw driver and bang at it until it comes off or you give up. In a couple of days when it comes off you can take the lens out (if you haven't cracked it or broken it in a hundred pieces) and the H-4 bulb. The LED will fit where the H-4 did and just plug it in.
Putting it back together the rubber gasket will fall off the outside shell which you won't be able to hold in place when you put it back together so you will toss it and your headlight will leak and rattle. :bang:
You will love the LED but hate yourself for not doing it right.
Have fun!
