I haven't had any problems with mine after the re-call on the spring. Chrome doing good. Maybe they changed suppliers!
I can tell you that when my spring came off I was going down the F-way at about 75 and was leaning into a corner and the kickstand came down and when it touched the ground it went into the lock mode! Thought it was going to kick my rearend out from under me. I did inform Ron at BDM and next thing you know there is a re-call out on it. :2thumbs:
This is at the longest position.I will have to go down to the shop and take more pics.I dont think it will be problem because its adjustable.I got this from the bd dealer that sold out. 05chop
I ran into problems with this arlen ness kickstand.I found out that the kickstand wont adjust to 8in.The lowest it will go is 9in.I decided to remove the leg and found that i can remove 3/4 inch from the leg and grind back the flat.I know its alot of money for these kickstands but im going to make this work.I got no help from arlen ness.I was told that this kickstand fits all bigdogs.I can go with a spacer behind the kickstand thats thats tapered joker machine sells them.they call it 6degree plate.I decided to cut the leg to make it shorter.I expected to find a spring and ball when i removed the leg and found only a threaded hole.I will take more pictures when done.So if you already have one ordered you have been warned.05chop
