I believe I read somewhere that there is a 20 amp fuse on each bus. That fuse should've blown when the power probe was activated.
That makes sense, however, I'm not there. You are the eyes and ears for everyone.
Pure speculation, I'm not clear, but, I assume you had power probe attached to battery.
For instance, my power probe will allow 65 amps to flow if I don't adjust it. So, if
over 20 amps was inserted into the circuit with probe, the fuse should be blown.
Result: no power on power-up circuit
