Clutch suggestions
prairiehorse
OK so got all apart. About 4 months ago replaced the basket. The outer ring gear/drive gear (where the clutches grip to...dont know the actual name) is all scored to shit. Called Baker as it is them whom i got the basket etc from a few months ago. They wanted to sell me the whole assembly for $700 (which i have all of it except that drive gear) or they would sell just the gear to me with new clutches for $600....WTF.
Gonna call bandit tomorrow as that just pissed me off.
stlmikie
I wish I had more money.
That just sucks. I'm sorry to hear about that P.
prairiehorse
Thanks for all the info folks. I have decided to go with the Bandit set up. only thing is i think i have to order the outer hub from baker, so there is another $$$.... SUCKS!
I really appreciate all you educating me though.
Cheers
Klay
Tim
Founder
Lifetime Supporting Member
Outer hub?
You'll be happy with the Bandit. :cheers:
05ridgeback
does bandit carry everything needed?...reason i ask is i will need the gear that turns the starter and i dont see it in the pics of there bruiser
prairiehorse
The piece i checked into was the "OUter hub sprocket" dssc #3023 i think is the part #. No bandit doesnt carry it. It's a baker part only...at least that is what i found. Thanks about the starter ring gear heads up. I am assuming bandit doesnt have that? They also said I will need a shim for the clutch as it goes onto the shaft since the bolts on the basket have a tendency to rub on the outer case......
Black Sheep
Got a question for the group. gotta 2005 chopper rt, barely 5000 miles when ( I thought) my clutch was going. What I mean is; when I crank on it at the top end of 2nd and third gear, I would feel what was a "jackhammer" in the seat of my pants. I thougt the clutch was slipping. So I had my Mechanic replace it with a Bandit Machine works clutch and basket. However, this did not resolve the situation. So I am open to advice at this point.
Brew
Sounds like your drive belt may be slipping. Check and see if your belt is worn and check your rear wheel pully for worn spots. Make sure your belt is adjusted correctly.
Black Sheep
That was my original thought, checked it out, and everything seems to be fine in that area. Even the mechanic dismissed it as the belt slipping. When I took it back to him for the 500 mile adjustment on the clutch, he then tells me ( after riding it) that its the tranny, and that I need to send it out to baker for a $1500 rebuild. So I guess, I am also fishing for info to see if this mechanic knows his stuff or not.
Que
I have a Bandit Clutch that I might be selling soon. Ordered a belt drive. Once it comes in I will be selling my primary and all the wet clutch stuff. PM if interested.
keithcuda
All this info about clutches... Will any of the clutches that Barnett makes fit in our bikes??? If the answer is no, the why the hell not?
wyatt580
Barnett makes the clutch cable... baker makes the tranny/ primary drive.....big difference.....but I know what your gettin at.....I agree gonna cost alot of money to play....torque box here I come...gonna have ta modify the tranny plate but then my open belt. Will be cheaper....also gonna have ta set up chain........ah just a dream....peace
keithcuda
yes i know who makes the cables and the tranny.. just wondering if their clutch will work in our bikes.. if not, is there any modifications that can be done so they will work..
also, are there any other open belt drives that are compatible.. all through this forum i only here of about two brands that people are using. and none of the karata drives catch my attention at all. So what is the difference in their drives that work with our bikes that no others do?
wyatt580
The tranny is made for big dog (proprietary)..you would have to change your tranny to have more options on belt drives and clutches..
