You're probably right.No offense, but you said not spend a lot of money.
You might not be able to get reliable and cheap, there might need to be a decision to be made.![]()
Didn't want to spend that much. I won't use it that much. Think I can get away with something less powerful?Kobalt=•155 PSI max pressure, 6.2 SCFM at 40 PSI, 5.3 SCFM at 90 PSI, 1.6 running HP
Just picked up one of these at Lowes Sunday. Had to replace my old Craftsman as it couldn't keep up with my new plasma cutter. I needed 3.5 cfm. These sell for around 475. You can shop and get cheaper. What ever you get I would get a piston type compressor just for the lower noise.
Not for any length of time, this is why I just bought the new one.Is a 15 gallon enough to run a grinder?
Gun control is not about guns, it's about control.
Say, how's it hanging? Yeah, you like the way I shined those up, yeah? They look nice. Maybe I'll buy a cheapshit compressor over at china boat is sinking finally. Yeah, you figure I could polish these out in a day, whereas I was reading over at the website about a guy spent 300 bucks on a 175 buck save. He was polishing about a quarter of the wheel in about 3 hours. Thing was, it kept on running and stopping just to get the kid's tires pumped up. Geee, so watt happened next? Well, after the 300th time his ears rang from that non-piston type pump, he started to smell smoke. WATT kind was that? You know when them chine knees units go out @ 300 buck a pop? No. Well, you see that bellow of smoke coming out of that motor? Yeah, that smoke. I now have to add 300 more dollars it's going to take to buy American, wear out I should have spent the extra 175, but now you see the cha-ching you go cheaping out in the cheap seats?Kobalt=30 gallon tank•155 PSI max pressure, 6.2 SCFM at 40 PSI... These sell for around 475. You can shop and get cheaper. What ever you get I would get a piston type compressor just for the lower noise.
might want to add a water separator/ 5 micron filter to add life to your tools.
Don't for get the 1/2" impact wrenchPolish wheels - OK, now what?
Bike tires
Car tires
Polish car
Spray car wash soap on [w/accessory tools]
Wash suds off [w/same tools]
Air dry car
Air dry bike
Lift the bike rack
Blow things clean like inside a computer tower, inside an enclosed fan.
Blow some up the shirt and cool off during the summer.
Blow up the toys for the pool, basketballs, etc.
Oh, you'll find more things to this short list.
I have one .... works fine, even painted my K9 with it ...I've read on other threads that Harbor freights compressors aren't very reliable. Any thoughts?
Which one do you have? Is it powerful enough to run the grinder?I have one .... works fine, even painted my K9 with it ...
