BamaMastiff
Yes I put it on a tender. All lights and everything works, I hit the run button then start and zero. No draining of the system. Just silence when I hit the start button.
Have you completed this step yet? Stater solenoid wire voltage?ok you need to pull the green( I believe ) wire from the starter solenoid & get a volt meter & check for power when depressing the start button.. also @ this time you shoule here the compression releases click for about 1 sec.. you need to make sure both arter working,,, just place you finger into the hole in the top of the rocker box when you depress the start button the copm. release will go down for a moment.. the starter solenoid wire will have aprox 6-8 vdc. when nouthing is depressed.. when you press the start button the wire should read the battery voltage.. aprox 12-13 vdc..
Bamamastiff,
Hey bud, I have been having lots of electrical issues with my 2009 Mastiff as well.
I want to go into arbitration because I am fed up with the bike breaking down.
Please drop me a line via email to discuss. bdm123163@yahoo.com
Thanks.
Why not toss up an INTRO, then go to the HELP WANTED section and let us know what issues you are having, what has been done to fix this issue, those results and let us help get you back on the road? Perhaps some of the other Huntsville riders might even chime in. We are here to help you with pup issues.:2thumbs:Bamamastiff,
Thanks.
