Timing 04 mastiff
Badazz
What is the best way to set timing on the 117? I tried to set it using the firing mark and tried using TDC mark. Niether seemed to be right.
Mickmorris
Well Known Member
I have a dyna 2000i ignition on it
You need to get the engine to TDC on the compression stroke.. Then with the key on & run button on you should be able to loosen the ignition and rotate it. When you do the light should come on and off. With the light on rotate it clockwise just until the light goes off. Lock down the ignition. This should be close to 32 degrees firing.
Mickmorris
Well Known Member
You would need to dyno the bike to really get that information. 32 degrees seems best at 2500rpm.
