If you look at the silver colored socket/nut tool I built, duplicate it, and you will have a tool that works like a champ. Cut down 11/16" socket with an 11/16" nut welded on it. Just long enough to get the short end of an allen wrench thru it, while holding the nut with an 11/16" box wrench. Works on most aftermarket, and Harley clutches.Is there a certain way to loosen the jam nut on a 04 pitbull? I can barely get a wrench to stay on it enough to loosen it.
Me too!Fwiw, I use a 11/16 offset wrench and a t-handle allen wrench. Works like a charm.
John, are you sure that’s the right picture? I have looked at it a few times & I sure don’t see anything looking like a 11/16” socket? MickIf you look at the silver colored socket/nut tool I built, duplicate it, and you will have a tool that works like a champ. Cut down 11/16" socket with an 11/16" nut welded on it. Just long enough to get the short end of an allen wrench thru it, while holding the nut with an 11/16" box wrench. Works on most aftermarket, and Harley clutches.
John
Mick,John, are you sure that’s the right picture? I have looked at it a few times & I sure don’t see anything looking like a 11/16” socket? Mick
