Just wanted to know if it mattered before or after. Thanks for the caIf the feed line goes from the oil pump to the filter, and the return line goes to the oil tank, what would be your guess? I would hope that you would put the return line from the filter to the cooler/s, and from the cooler/s back to the tank.
John
Basically, you just remove the oil filter from the engine block, fit the New 2 port adapter in place where the oil filter was removed From and reinstall the oil filter on to that Adapter..
Then the Oil Cooler pipes go into THAT Adaptor.
No wonder your having problems!
This is where I bought the Cooler kit..
He's still selling the kit with that Adapter.. He may sell the adapter separately..
Big Dog Motorcycle Chromed Oil Cooler | eBay
DUAL (2) OIL COOLER SETUP!!! RATE THIS ONE A SOLID 10 PLUS. U WONT BE DISSAPOINTED. NOTE :Oil filter not included (Or See Below) If you have crank sensor that is too close to filter you will have to add two small spacers (washers will do) at filter mount to off set the filter back, easy cheesy...www.ebay.com.au
It's hooked up to the outlet on the oil filter housing. It cools the oil after it's run through the engine and filtered.Just wanted to know if it mattered before or after. Thanks for the ca
The don't come with that adapter no more. It only comes with this now. If I had that adapter that hooks to the oil filter I wouldn't have asked these questions. Wish I had it.
It's cooled then coupling is used on the return line to get the cooler oil back to the tank.
The adapter isn't needed.
The 1st line on the oil tube that I have circled in orange in your picture. where does that attache to? Is that the inlet or outlet on this cooler? I just bought double set up and dont want to hook these up wrong. Thanks
