Glad you solved the issue!! Curtis is one of the best!!
Same issues connecting my 2010 Bagger when I needed to clear a check engine light. I looked all over for an old laptop with the correct 9 pin serial port, to but no avail. The cable only uses three of the pins. I read the instructions from the Protune II download from S&S, and had a friend make me a cable with the correct serial port 3 pin connection (he simply removed the unneeded pins) to connect to the bike, and attached a 9 pin/USB adapter to connect to the laptop. I hooked it all up but the software would not detect a signal from the bike.
Roger had a connector (Thunderheart?) from an ignition module he bought some time back for his K9. It was a 9 pin serial port to USB, and using that with my cable, it worked like a charm.
If you have an old laptop with a 9 pin serial port you can make a 3 pin cable and be in business. I found any old adapter (9 pin to USB) would not work-S&S made a one that was proprietary, but they are no longer sold.
Although limited in my ability to sensibly discuss technology, here is what I did to get connected to clear my check engine codes:
Downloaded Protune II from the S&S website to the laptop. The only serial port on it is an 11 pin (useless in this case) and of course USB ports. S&S warns not to use a standard 9 pin serial port cable/connector, as it will allow excess current to pass thru that could damage the computer, as I remember. Be sure to go to the S&S website and look at the info accompanying the Protune II software, as it explains this.
Went to a tech buddy of mine and asked him to make a 3 pin serial port cable following S&S instructions (using a 9 pin—they simply didn’t wire unneeded pins. I think you could also just snip the unneeded pins out too. Mine was made with three wires.
I borrowed the adapter from Blacktopper—he has the cable too— (If you PM him and say you know Mastiff Dave or Mr. Wright, I bet he’d let you borrow it). See photo below of the adapter driver that came with the cable.
Sorry for the fuzzy picture, but you can tell which pins are used.
This is the package for the cable that Blacktopper bought that allowed the connection.
