25" -- Although if I were to do it again I'd probably go 30" at least!Awesome bar Mike
How tall is that?
Sent from my SAMSUNG-SM-N910A using Tapatalk
That is my only complaint. The bag sagging. Other than that the Ginz is awesome.25" -- Although if I were to do it again I'd probably go 30" at least!
The best part with the wide rack my luggage doesn't sag anymore!
Ginz makes the bars with luggage racks alsoThat is my only complaint. The bag sagging. Other than that the Ginz is awesome.
I have one but the design I got the bag has a little sag. Not a big deal but I would have changed the design a little to help that.Ginz makes the bars with luggage racks also
that's why I worked with them, since the bag is on the bike 95% or better, function was more important than style.That is my only complaint. The bag sagging. Other than that the Ginz is awesome.
Not a bad idea. I was thinking more thin piece of lexan or something that is flexible but rigid and put at the bottom of the bag. It's mainely my roll bags that sag on me.that's why I worked with them, since the bag is on the bike 95% or better, function was more important than style.
If you've got sag, get some clear 5/8" id tubing, a sheet of diamond plate and make a plate as wide as you need.
Cut some slots to line up on the sides of the luggage rack (2 outside of bar two inside of bar on rack on each side)
Slice the tubing open, place it over the luggage rack.
Place the diamond plate on the rack and use zip ties to hold it on.
The tubing will protect the luggage rack from damage and it will go on and off again easily.
My way you don't loose any storage capacity -- every little bit counts on a chopper!Not a bad idea. I was thinking more thin piece of lexan or something that is flexible but rigid and put at the bottom of the bag. It's mainely my roll bags that sag on me.
Is that the 15 inch bar hopper ?Not mine, but most will know the bike... by the blinding shine..
No idea, its Kevin's..Is that the 15 inch bar hopper ?
Looks goodI got my new 23" Rolling Hell from Ginz installed today. I think it looks just right![]()
Looks damn goodMy new to me Ginz
ATTACH=full]68480[/ATTACH]
I just talked to Gin the other day - their still working.Tried to get on the ginz choppers website for several hours last night at work and kept getting an error. Have they closed their website down or maybe even shut down themselves?
