Oil seal open primary
Dog goner
Thanks in advance for any help I receive.
This bike new to me. 107 bulldog.
Someone put aultima 2" open primary on.
Had oil leak. Seal was not in backwards.
So I did that . Still leaked.
Back apart and found part that seal that Marrys to on crank is spinning ok crank. Not spinning in seal.
Also does shoulder on this part go in or out.
Proper name for spacer?
Thanks again
Thanks again
That spacer is for the open primary only, might want to double check and get ultima install document. Should be on their website
The shoulder in or out would be in those directions. It should mate nicely one way vs the other against that bearing can't tell by the pic. Although it doesn't look like the standard offset spacer so I'm a bit lost. Maybe someone who has an ultima will know?
Also that outer bearing race around 2pm looks bent!
mastiffdave
Check for the slightest nick where that seal will mate . I put several in my baker and finally took my time to check the mating surface and found a small almost invisible nick. Your fingernail would hardly catch on it but some emery cloth to smooth it up and never leak again.
Dog goner
Thanks
Research found I need a spacer between spacer and magnetic.Was in pile of parts I for with bike. Sand down spacer found nick.
Oring was bad.
Good eye on the bearing pic.i came out right then. Bad pic.
Order parts hopefully that a rap. Want to ride not wench.
My shovel and I got along very well. Hope it will happen here.
Thanks
Oring was bad.
Nice, didn't look the spacer I would have expected but sometimes you never know what goes in the bike before you buy them.
