Would like to remove my passenger foot pegs.
badyellowvette
Looking at the left side closer the base coat color is showing through the red but the right side not so much. I might be able to polish the right side out. On the left I took a piece of fined aluminum and cut it to the shape of the mark. Stuck it on there temporary, not sure what I think, thinking I don't like it.20190602_155124.jpg 20190602_155124.jpg 20190601_162654.jpg 20190601_162702.jpg
Looking at the left side closer the base coat color is showing through the red but the right side not so much. I might be able to polish the right side out. On the left I took a piece of fined aluminum and cut it to the shape of the mark. Stuck it on there temporary, not sure what I think, thinking I don't like it.View attachment 65287 View attachment 65287 View attachment 65288 View attachment 65289
Through in a blue stripe or two and USA!
I like that.
Yea, I bet it would look cool! Not sure if that's a blue or grey Flame but I think it would be a little nice custom touch! Also could help if you can't match the red on the bike to show its not a stock piece
I think it looks good as is really
pknowles
RETIRED
Round the corners over just a bit to help tie in with the swingarm. Just a thought
Jersey Big Mike
100K mile club
You could also make them a little bit bigger than what you need and do a stylized American Flag waving. I think that would look good.
TexasMike
Hey badyellowvette - Did you ever come up with a final solution you were happy with on this? If so, I'd really like to see it. I took my pegs off & there where deep scratches and scraped off paint areas that the brackets were covering. I did a quick search to see if anyone else had ever mentioned trying to cover the area & ran across your thread.
Jersey James
Jersey James
This is the chrome part that holds the oil tank to the frame on an American Iron Horse Motorcycle ~ LSC & Tejas. It measures 2 1/8 inch at the longest part, looks like a pretty near match. I can give you better measurements ( center hole to center hole, width etc. ) If you think it may work. Can also supply where you can purchase them.IMG_20220130_232312.jpg
TexasMike
That does look like it might cover the a majority of the area, and might work with a couple of flat head socket screws to look "flush". The center to center for the bolt holes appears to be 1-3/8".
Jersey James
Jersey James
Texas Mike. Without removing the bolts (PITA), I measure across the center of the top of the bolts. Closest measurements I get is 1 1/8" center to center. Hope this helps.
TexasMike
Turns out the areas I thought were "chipped" paint was some sort of build up that I was able to get off using a razor blade (carefully). There was some excessive coated areas, like others had described, and some deep scratches right around the bolt holes. After buffing the hell out of it, I used some chrome flat head bolts & countersunk washers to help cover the scratched areas.
badyellowvette
I did eventually make a better-looking bracket and it turned out awesome I use the same type of material I will try to find a picture because the bike is put away at the moment.
