Does that speedo have a voltmeter mode?Hooked up the old battery only reading around 10volts.
Speedo works, turn signals are dim and horn works , no headlight . New battery will be shipped tomorrow
It does not. I checked the battery with my multimeter and the readings are all over the board. I think this battery is junk but they are sending me another one at no charge. I may keep it as a spare and order a Braille . I plan on using the new battery to check out the esc and all systemsDoes that speedo have a voltmeter mode?
Additionally, when I put the battery on the tender the lights flash all over on the charger not showing a full charge. I think when the big bear quit the battery took a shitDoes that speedo have a voltmeter mode?
She's almost "Ready To Rumble" Cant wait PaulHooked up the old battery only reading around 10volts.
The blue speedo is from the pitbull , not really worried about matching the color on the speedo.Looks like you went with the blue Dakota for visibility even though you have a red bike ?
I hate digital gauges, but I haven't seen anything offered as reliable alternatives. I guess you didn't find anything either ?
Not long now.Hooked up the old battery only reading around 10volts.
Pictures please!Update, well after new battery was installed everything but the headlight worked. Switched out to a standard h4 bulb and sure enough the light works.
Cheap pos Chinese daymaker!!! That’s what happens when you use cheap shit on our bikes.
Brand new and it’s shit.
Everything else is working as it should ,
Not yet ,Pictures please!
Yeah but when it's done. What a beautiful feeling.Not yet ,
Having some problems with getting all controls to work.
Docs esc is awesome and I am sure I fucked it up somewhere. Now I am trouble shooting
Here is what I have, left hand control all functions work .. horn, high and low beam front left turn signal. No rear turn signal.
Right hand control , no functions work
I have lights on all 4 turn signals ...
I did just replace the right pcb board ..
1 step forward .. 10 steps back
Most likely it's just the connection at the PCB board cause it's finicky if you don't get it right but if you don't want to take the hand control apart first then just jump the pins for the right turn signal at the gas tank connection since you got the tank off and it's right there and see what happens.Not yet ,
Started with the tank connection and I had the wires in the wrong pins. Fixed that but still having the issue. I am going to check the pcb board connection nextMost likely it's just the connection at the PCB board cause it's finicky if you don't get it right but if you don't want to take the hand control apart first then just jump the pins for the right turn signal at the gas tank connection since you got the tank off and it's right there and see what happens.
If it works there you'll know the issue is definitely north
Got it figured out ! Because I had to take the jst connector apart originally my wires were off, after reviewing my notes I changed them around and sure enough everything is working.Most likely it's just the connection at the PCB board cause it's finicky if you don't get it right but if you don't want to take the hand control apart first then just jump the pins for the right turn signal at the gas tank connection since you got the tank off and it's right there and see what happens.
