should the oil be visible in the up position or the down position? seems like it would make a difference.
With the ram closed the reservoir level should be nearly full I would think.I would think down.
X2With the ram closed the reservoir level should be nearly full I would think.
Ah now the secret is out. I do not like to strain working, I always look for an easier avenue to get things done, if to difficult you hire someone or get some body who has a strong back and weak mind.Ah, now I know where Eric get his brilliance from.
Yea, I just learned from his dumb ass mistakes...whatever Dad does go a different route! HahaAh now the secret is out. I do not like to strain working, I always look for an easier avenue to get things done, if to difficult you hire someone or get some body who has a strong back and weak mind.
Thanks, smart ass son of mineYea, I just learned from his dumb ass mistakes...whatever Dad does go a different route! Haha
Didn't mean to start a family feud.Thanks, smart ass son of mine
Great idea. That’s what I was thinking.I have to place a piece of three quarter inch plywood under the steel ramp to get my prosport on without bottoming out. Make it as wide as the ramp and about two feet long. The bike will ride up on the plywood then onto the ramp. Easy fix.
Get some good motorcycle tie down straps to secure you're pike to the lift.
Also replace the skinny little bar they use as a safety bar with a larger one. My holes are big enough to accept a one inch diameter bar. Also this should go with out saying don't try to move the lift with the bike on and raised up. Ain't nothing good going to happen.
Yep $289 through this weekend.They have a coupon on the lift for this weekend Friday ,Sat. Sun. $289
you will have to just trim the back so it doesn't hit the fender.Hey Eric does that wheel chock fit the front fender for the K9 without hitting it?
The Back? What part of the fender does it hit, the front of it ?you will have to just trim the back so it doesn't hit the fender.
