Paint Saver Ring Removal
Radams1945
Hi all,
So, the old stuck gas cap issue! I was able to remove my gas cap finally, bought 2 new aluminum thread pop up style caps, to avoid that issue again. But now can't get the paint saver rings off! I purchased the removal tool, after waiting 2 weeks to get that, go to use, within moments broke off one of the tabs! Also tried the hammer and screw driver but is digging into the ring! UGH! Does anyone have any suggestions?
Please Help!
SKOGDOG
One of the old ones.
Finish grinding off the broke tab. Drill and tap the removal tool for a couple 10-32 set screws.
Or you can PM Skroggdog, and tell him to finish using the one I made, and have him send it to you.
Yes-I am through with the tool and can send it to Brian if he needs it, or to Shannon. Thanks to Shannon for his generosity.
Just pm me an address and I'll have it out ASAP.
Ernie12
spray some silicone underneath the paint saver and let it soak a while. It should soften up the rubber gasket and make it easier to get off. I did that to mine and it came right off.
pauly
I have filled my tank with water and used a heat gun on the paint saver to heat it up
till it was nearly hot to touch and unscrewed it with the tool.
I did not care about the paint as I was going to repaint it anyway. No paint damage thou.
Paul.
pknowles
RETIRED
Paul.
It would be interesting to know the name of the silicone spray that released the seal without damaging the paint. I was thinking the heat gun would work with the tank purged.
Ernie12
I know I have a good coat of polish on the tank but I never even thought about the silicone damaging the paint. I think it was made by Liquid Wrench , I guess you could try WD 40 also. I did not spray it like crazy , I had a rag around it the whole time and just used little squirts so there was no over spray.
Also I just remembered that there was some kind of thread sealant on the threads. Maybe that is why he is having such a hard time removing them.
pknowles
RETIRED
Well Ernie, it's good to know that it won't mess up the paint. And, I think you are right about the sealant. Seems like some have done damager to the tank trying to get the threaded portion out.
Radams1945
Thanks guys for all the tips. I will try the combo of WD-40 and a heat gun. The seller I purchased the removal tool on Ebay sent me a replacement, which was cool. Will let you know my results.
Radams1945
Forgot to update. I finally was successful! After a 2nd removal tool, spraying WD-40 under paint saver, slight heating with heat gun and crescent wrench. Didn't even need much torque! Thanks again guys. Of course now I have the issue of removing the remaining parts of the
rubber gasket that is hard as a rock! Tried shaving off with blade, some came off but worried about having an accident and further damaging my paint around opening.
kyle
I got a little bubble going on, not much but a little and have been thinking about replacing the cap with the kuraykin recessed one.. just not sure I want to get into something that would down my bike for a month if it goes sideways
Sent from my SM-N950U using Tapatalk
So what was the results
