All sorted out..
That vent pipe used to go into a Carbon Canister and any fuel, fumes got sucked into the engines intake once the engine has started..
The vent under the tank goes to the top of the inside of the tank just below the fuel cap.. Theres a round plate inside the tank just below the filler cap and where the Top Vent intake is.. I fitted a plastic tubing in the top vent in the top of the inside of the tank to raise the vent pipe by 10mm .. So when fully filling the tank ( but below the round plate ) there`s less chance of fuel running into the top vent and then dripping out of the bottom vent under the tank..
Ive fitted a braided line from the bottom vent of the tank and ran it down the bottom of the the bike frame..
The braided line i used has a small orifice ..........
The filler cap has a one way valve to only vent into the tank, so no fumes can vent out from the fuel cap..
