Having an issue with wheel hop
If it's lighter can I do on the k9 what the guy does in this video? Watch the chopper
that's george mingledorf out of low country customs in savannah, ga. where Shane and I bought our dogs. and, yes, he is crazy enough to do that shit. problem is, he never told the prospective buyers that he did that to the bikes. he did this down below the Talmadge Bridge on Hutchinson Is.
the theory of the light front end could also be backed up by the videos of Sugar Bear and his posse bouncing their bikes down the road with his springer front suspensions. damn, some of them look like they are 8' long just by themselves.
I havent noticed any wheel hop with the Pitt, but the full fender this weekend sure made my hands tingle. It catches more air which adds vibrations. Shorty goin back on this week..
cdogg556
That's really strange I don't know if it's your fender, I have a full fender on my bike and it's stable over 130 miles an hour, so I don't see how there's any way you could be your fender.
mjsk9
It was at 30 psi . I'm not taking anything to that shop again. I had them change the front wheel bearings and the tire, while they had it. My bad for not checking the pressure when they gave me the wheel and tire to put on the bike.
Probably want to recheck the tire pressure in a few days to make sure there is no leak or didn't seal properly after they put on the new tire?
kickstart
Has the oil in the front end been changed? I noticed some hop when I changed oil and tried 20, 30 works better for me. As far as your question of is more beads better, I cannot answer
i'm having an issue between 70 and 80 mph. My new front tire will start to bounce at just over 70 mph and just at 80 mph it stops. Then it's smooth as ice. is there a such thing as too much with the beads?
Has the oil in the front end been changed? I noticed some hop when I changed oil and tried 20, 30 works better for me. As far as your question of are more beads better, I cannot answer that but I would stick with the recommended weight.
That too...i tried 20wt based on some recommendations here think GasMan likef 20 I had to drain it and run 30wt.
You gotta go faster than 70 ..lol..
It's just a little hop and you can't really feel it but if your looking at the tire you can see it. Might not actually happen on your old pitbull actually just because there is more weight on the front end. I bet it doesn't on the prostreets just because of that. Longer bikes just don't have much weight on the front tire.
Give it a try on your k9..and it's usually about 68mph - 77mph it just has a little bounce it's not smooth. Again you gotta be looking at it you won't really feel it
Not much difference at all between K9 and Mastiff, 8#
oss
I was changing my headlight bucket. and went back over what I had found the other day. I got a half turn on the valve on my front tire. Sorry I did't post sooner. I'm betting that was causing my slow leak.
