How much did you put in?Yes, that's why I was asking if you could put too much in the tire. I was thinking it was the tire.
Sorry, had the volume turned down..Reread op and put your hearing aid in
Sorry, I stepped on them grabbing my hearing aid..Put yo grasses on
What was the PSI?Thanks !!! That was the issue, next time I'm checking, " their work" or doing it my self.
You gotta go faster than 70 ..lol..I've had my front tire as low as 25psi only to feel is was tough to turn never got a hop or wobble
WTHYou gotta go faster than 70 ..lol..
It's just a little hop and you can't really feel it but if your looking at the tire you can see it. Might not actually happen on your old pitbull actually just because there is more weight on the front end. I bet it doesn't on the prostreets just because of that. Longer bikes just don't have much weight on the front tire.
Give it a try on your k9..and it's usually about 68mph - 77mph it just has a little bounce it's not smooth. Again you gotta be looking at it you won't really feel it
I wonder about the Dyna beads too..sometimes something like this where there is only a hop at a certain speed makes me wonder if it's the Dyna beads causing the issue and for whatever reason If the pressure in the tire isn't >40lbs it messes with how they move around.Was talking to a guy this morning before I left Dave's that was having the same problem. They broke the tire down and took the beads out, the spun balanced it. They did it 3 times and with out any beads in it, it was perfectly balanced. Put it back on the bike, and wheel hop was gone. Could be something to that.
? How is that not true? If you have a shorter stance and less rake there is more downforce created on the front end.
So if its out there far enough there won't be any weight at all on it right?? How is that not true? If you have a shorter stance and less rake there is more downforce created on the front end.
Not to mention the rims, tires and fender are heavier on the mastiff and pitbull due to the width. So there certainly is more weight on the front end.
