Not zero weight but I imagine there is some math to the weight / rake ratioSo if its out there far enough there won't be any weight at all on it right?
that's george mingledorf out of low country customs in savannah, ga. where Shane and I bought our dogs. and, yes, he is crazy enough to do that shit. problem is, he never told the prospective buyers that he did that to the bikes. he did this down below the Talmadge Bridge on Hutchinson Is.If it's lighter can I do on the k9 what the guy does in this video? Watch the chopper
Wouldn't that depend on how much engine horsepower was applied to the rear tire?So if its out there far enough there won't be any weight at all on it right?
Always nice to have an alternate rideAlso when I wana go over 70 I break out the z1000 the dog is my feel cool cruiser
Probably want to recheck the tire pressure in a few days to make sure there is no leak or didn't seal properly after they put on the new tire?It was at 30 psi . I'm not taking anything to that shop again. I had them change the front wheel bearings and the tire, while they had it. My bad for not checking the pressure when they gave me the wheel and tire to put on the bike.
Has the oil in the front end been changed? I noticed some hop when I changed oil and tried 20, 30 works better for me. As far as your question of are more beads better, I cannot answer that but I would stick with the recommended weight.i'm having an issue between 70 and 80 mph. My new front tire will start to bounce at just over 70 mph and just at 80 mph it stops. Then it's smooth as ice. is there a such thing as too much with the beads?
That too...i tried 20wt based on some recommendations here think GasMan likef 20 I had to drain it and run 30wt.Has the oil in the front end been changed? I noticed some hop when I changed oil and tried 20, 30 works better for me. As far as your question of is more beads better, I cannot answer
Not much difference at all between K9 and Mastiff, 8#You gotta go faster than 70 ..lol..
It's just a little hop and you can't really feel it but if your looking at the tire you can see it. Might not actually happen on your old pitbull actually just because there is more weight on the front end. I bet it doesn't on the prostreets just because of that. Longer bikes just don't have much weight on the front tire.
Give it a try on your k9..and it's usually about 68mph - 77mph it just has a little bounce it's not smooth. Again you gotta be looking at it you won't really feel it
Or 10...Always nice to have an alternate ride![]()
