Well at least ya know what it is. Sucks it's not a cheap part but at least an easy fix.Update -- the Annunciator is toast one of the chips is fried (not capacitor) near where the damage is in the pic that was already posted by someone else.
Low fuel still is out but I can probably get around that -- might need a transistor and a resistor to fix that worse case.
While I have it apart, I'm replacing the fuel filter and doing some other work. Be ordering new annunciator from Curtis today.
Do you have a part number?Well at least ya know what it is. Sucks it's not a cheap part but at least an easy fix.
Interesting that is 3 annuciators fried in the last year I'm aware of and literally first time I've ever heard of them going South.
While you got the fuel pump out just replace the thermistor just incase that's the culprit on the fuel light. I think that thing is only a couple bucks.
Well if I could tell what chip it was I actually might be able to (or if I had the annunciator shematic) but at my age the eyes aren't what they were once but probably could still solder a new chip in if I had to.Yep, didn't think you would be able to fix it.
Problem is Mike, depending how deep it burned into the laminate/board and how many tracers did it take out and melt together would determine if its fixable or not.Well if I could tell what chip it was I actually might be able to (or if I had the annunciator shematic) but at my age the eyes aren't what they were once but probably could still solder a new chip in if I had to.
Might want to ask Curtis when you order the tach ring.Do you have a part number?
the burns not that bad.Problem is Mike, depending how deep it burned into the laminate/board and how many tracers did it take out and melt together would determine if its fixable or not.
But then you would have to worry about the retaining ring that holds it in fitting back into the slot, maybe you didn't get that far yet.the burns not that bad.
Given the complexity of a tach circuit or actually lack thereof with a brun in one area like has been shown recreation of traces could easily be done with jumpers just like you were doing a revision after the board etch.
Not being able to read any chip part numbers and the damned enamel/plastic coating added on top of the board to prevent shorts is more of an issue.
I've already ordered one from Curtis
Speaking of retaining ring.But then you would have to worry about the retaining ring that holds it in fitting back into the slot, maybe you didn't get that far yet.![]()
No I got that far just commenting on the pain it would have been.But then you would have to worry about the retaining ring that holds it in fitting back into the slot, maybe you didn't get that far yet.![]()
I'm sure that rubber ring doesn't come with it and its still ok even after I removed the board.Speaking of retaining ring.
Mike be careful with the foam around the tach ring that does NOT come with the ring and I think the foam is pretty hard to find...go figure.
